Old 01-08-2006, 05:24 AM
clinthart's Avatar
clinthart clinthart is offline
Default New Update to Project Quicksilver.
Here is a link to some pics on my web site with of the new doors and fenders I have just started to fit. This is the initial fitting of the panels, and still need some serious tweaking.
http://www.project-quicksilver.com/F...rs/default.htm
The drivers side is the closest of the two. The passenger side door needs to slide back about 1/8", and then I probably need to add some metal to the edge to get it closer to the gap size I want.
Hope you like the pics.
Old 01-08-2006, 07:42 PM
Kendall Burleson Kendall Burleson is offline
you will need to make sure the core support is center before you weld any thing.
Old 01-09-2006, 04:49 AM
clinthart's Avatar
That is a good suggestion, but the core support is not exactly square, so what points do I use to measure it up? I was more concerned with getting the fenders squared based on several points I have yet to identify. And I wasn't going to do that until I had the upper and lower valance installed.
Old 01-09-2006, 05:42 AM
B Schein's Avatar
B Schein B Schein is offline
The area that I would pay the most attention to is the fender gaps. The square ness of the hood opening, alignment of the hood latch, and how well the grill fits. Then work the rest of the parts to fit after you get these things taken care of.
I usually leave the core support lose until I get everything else where I want it. The core support has more adjustment at the body mounts than any of the other front end pieces.
Brian
Old 01-09-2006, 06:18 AM
clinthart's Avatar
That makes more sense to me than squaring the core support, and was actually how I planned to do it. And since I have an after market hood mechanism (reverse power hood kit from e-life.com) I really need to get everything on and squared before I start filling gaps with weld.
Thanks!
Old 04-30-2006, 06:17 AM
clinthart's Avatar
Default Latest update
Here is a link to the latest pics of QuickSilver. It is finally starting to look like something.
http://www.project-quicksilver.com/2...29/default.htm
Old 04-30-2006, 06:31 AM
Datsbad's Avatar
Datsbad Datsbad is offline
LOOKS GOOD CLINT .
Keep in mind that when you put in a grille and finish the car , the backside of that rad support you are going to see it right throught the grille being silver. i would paint the backside black so when you get a front shot you wont see the silver jumping out through the grille.
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 04-30-2006, 06:36 AM
clinthart's Avatar
Originally Posted by Datsbad
LOOKS GOOD CLINT .
I have thought of that, and it shouldn't be that big of a deal with the grill being of a similar color. If the grill was black, then yes it would a big contrast.
Old 04-30-2006, 06:39 AM
Datsbad's Avatar
I am sorry i guess i should have asked what color the grille was going to be first
should look really nice when finished !
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 04-30-2006, 06:40 AM
clinthart's Avatar
Thanks man!
