Old 11-14-2010, 05:21 PM
zcrz zcrz is offline
Default ls1 e-brake adapters
Does anyone make an adapter for the rear parking cables to connect with the factory 69 camaro front cable? I did the brake swap and never messed with the ebrake. Want to do it this winter..
Thanks gurus
Old 11-14-2010, 05:55 PM
lil427z's Avatar
lil427z lil427z is offline
locar.com
Old 11-14-2010, 08:32 PM
aany001's Avatar
aany001 aany001 is offline
Originally Posted by lil427z View Post
locar.com
X2 its Lokar.I used their setup and it worked mint!
Old 11-15-2010, 05:06 PM
thanks, i'll check it out
Old 11-15-2010, 05:10 PM
did you buy brackets to adapt factory or use the universal fit stuff? Do you have part numbers? If not i'll call them.
