Old 11-20-2010, 07:13 AM
DOOM's Avatar
DOOM DOOM is offline
Default Help!!!!!!!
I'm getting ready to weld in my lower firewall. But for three days now I have tried everything to make this thing fit to no avail. The issues are endless. Right now as you can see in my photo bucket pics I have the sub bolted in. it bolted right up no problem. Now keep in mind that all the mounting points are from my old UNDAMAGE locations. Everthing as of now has set right in,upper cowl no problem I also made a jig off the old one before I cut it out. I set the new one in the jig and it welded in perfect. The floor literally fell into place! Then I set the lower firewall/toeboard in and now the issues are extensive. I two main issues the right side rocker is about one inch from the toeboard. The left side right at the area that the firewall meets the upper cowl it out about an inch. Now if I push this back with the portapower I can get it to sit where it needs to but then it pushes the area down where the floor meets the toeboard creating another issue.Then the next problem is the subframe mouting points all change because I'm forcing everthing back. Like I said before the subframe bolted right in.. I have to believe that this lower firewall is just made wrong. Has anyone run into these issues with these aftermarket firewalls??? If anyone has any ideas give me a call its alot easyer to explain whats going on. This is just a general discription of these issue. I'm tring to get some pics up but my camera is giving me fits. 708-751-8432....
Mario
USCOLLISION
Old 11-20-2010, 07:28 AM
elitecustombody's Avatar
Just to be sure, did you take a measure to see if the floor was square?Assuming you're replacing a full floor.Did this car sustain some sort of collision previously? What brand sheetmetal are you using?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 11-20-2010, 07:39 AM
DOOM's Avatar
No previous damage. I did replace the whole floor. I purchased the firewall from DnR CAMARO it came unboxed I don't know what brand it is. everything measures square.
Mario
USCOLLISION
Old 11-20-2010, 07:56 AM
DOOM's Avatar
And of course I just talked to DNR CAMARO and the never had any problems with these firewalls. So I'm the only one on the planet with this issue.... Imagine that...
Mario
USCOLLISION
Old 11-20-2010, 10:04 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Curtis
Old 11-20-2010, 10:47 AM
DOOM's Avatar
Just been informed DYNACORN is the only one that makes these firewalls... I have no idea if this is true or not.....
Mario
USCOLLISION
Old 11-20-2010, 02:32 PM
DOOM's Avatar
Done!!! Mike Riggs at MCC came to my rescue!!!!!!! He trully is the man and I'm not as dumb as I thought I was......
Mario
USCOLLISION
Old 11-20-2010, 03:16 PM
awr68's Avatar
awr68 awr68 is offline
Well now that has to make your day! Or week from the sound of it! What was causing the issue?
Tony
'68 Camaro
Old 11-20-2010, 03:40 PM
Jay Hilliard's Avatar
Glad to hear you got it figured out! What was the problem?
Jay
Old 11-20-2010, 08:21 PM
x2,so what was it?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
