Old 11-20-2010, 10:46 AM
Travis77's Avatar
Travis77 Travis77 is offline
Default headliner w/ cage ?'s
Anyone have interior pics of headliners installed that either hide the cage window bars or blend them in nicely? My window bars need to be moved upward into the side channel to give more head clearance. Thanks
67 Fastback 418, hogans upper, FAST efi, Richmond 6spd, global west front, homebrew 3-link, mini tubbed, baer brakes with hydroboost, pilot sports on Ze Boost wheels
Old 11-21-2010, 06:24 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Stock headliner can't be used to cover bars unless you have it sewed special.
TRACY WEAVER
www.recoveryroominteriors.com
Old 11-24-2010, 06:10 AM
Travis77's Avatar
I guess I should have asked for custom headliner pics. I wasn't expecting a stock one to fit regardless of vehicle. Thanks. You have any examples Tracy?
Old 11-24-2010, 01:29 PM
ModernMuseum ModernMuseum is offline
I have taken a few I believe. I have an aftermarket headliner and a DSE cage, but it's the stock style I believe. I'll try and post up some photos tonight.
The bars are approximately 3/4" from the headliner at the closest point. I had to tape paper sheets to the headliner when I painted it and could barely get the (spray) paint up there.
Old 12-02-2010, 05:46 PM
Jim Nilsen's Avatar
Jim Nilsen Jim Nilsen is offline
I decided to do my headliner with the perforated aluminum because of the clearance issues with the headliner. You could also do one with foam board and velcro and the headliner kit material you can buy at most Pep Boy's or other auto parts places.
May the Horsepower Be With You !!!!
Old 12-02-2010, 07:55 PM
fireboy68 fireboy68 is offline
Default Headliner
That is a great question, i have the same issue going on. I tucked my cage up to the roof as close a i could, i was told by all the off road guys that build the full cage trucks that they glue the hearliner in and wrap it around the cage and it looks real clean. I dont have any pics, nor have i seen it done, but i hope when i get to that point in my build it all comes together. Good luck, hopefully someone will show us some picts
Old 12-03-2010, 01:51 AM
LowchevyII's Avatar
LowchevyII LowchevyII is offline
definitely a question im interested in as well. would love to see some pics. and Fireboy68 what do those two aluminum cylinders on the package try do? those are the main supports right?
Jeff Weidner
1970 nova in pieces
Old 12-03-2010, 06:08 PM
Default headliner
Haha yes those are a much needed support cylinders. Good eye, thought nobody would see those.
Old 12-03-2010, 07:30 PM
Travis77's Avatar
Thanks for posting the picture. That sure is a tight cage. Unfortunately I refuse to take my roof panel off. Don't make me do . Surely we can come up with some pics of a finished interior with a trickerie headliner. May have to go underground for this one.
Old 12-03-2010, 07:44 PM
Bryce Bryce is offline
Fireboy,
I dont want to be critical, but your cage will not pass an sanctioning body for racing. Its not a continuous main hoop and the rear supports look to have a splice.
