Old 11-24-2010, 12:28 PM
Default Awesome New Pre Wired Fused Multi Relay Panels
Need relays for:
Fuel pump?
Electric Fan (s)
Headlight motors?
Nitrous?
Amplifiers?
Anything with a heavy draw, more then 10 amps should be run on a relay. Many components have a low continuous draw but the start up hit is a very high amperage like electric fans for example.Multiple relays can get pretty messy, hard to attach and hard to trouble shoot.
I am so excited I found a way to clean up PIA relays and fuses. On the left side of the first pic is what I had in my Street Racer, on the right is our new Pre Wired Relay Panel. These things are so cool. One power wire and one ground wire powers all the relays, each is fused, hook up the signal wire and output wire and it is all done. No making a panel, looping power and ground wires. As close to plug and go.
My Street Racer has Dual 16" fans (28 amps hit each, 12 amps each continuous), Electric water pump (16 amps continuous), and 2 stages of NOS (33 amps per stage). These Relay Panels house (5) 40 amp relays all in a compact 8"L X 3"W X 2"T package
We have these in stock in 3, 4 and 5 relay versions and will customize label the Relay functions on the relay panel and send custom instructions for your specific application like the ones you see in the pictures.
The Prices are as follows
3 Relay Fused Panel $249
4 Relay Fused Panel $269
5 Relay Fused Panel $289
On the left shows the way we did it back in the old days, now we have a MUCH cleaner package.
Panels will come, at no additional cost, custom labeled for your specific needs, or blank if you choose
We will also provide, at no additional cost, detailed instructions for your specific needs.
Frank Serafine
Old 11-24-2010, 12:57 PM
youthpastor's Avatar
very cool product! I like the elimination of a bunch of power wires
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 11-24-2010, 04:23 PM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
Awesome product, going to have to keep that in mind when i get to updating my wiring.
Kyle
Old 11-24-2010, 06:13 PM
scherp69's Avatar
scherp69 scherp69 is offline
That looks awesome Frank. Added to the list of things to get. I see some of the items that you have on yours, but what other items would need a relay for that would likely be on most cars? I'll have a dual fan set up on mine, but not sure what else might need a relay, other than the ones included with the Highway 22 kit.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 11-25-2010, 12:40 PM
Fantastic Frank!
Old 11-25-2010, 05:45 PM
ma73z's Avatar
ma73z ma73z is offline
Holy crap, another thing on my list to order from Frank.
