Old 11-26-2010, 06:05 AM
arrowem arrowem is offline
Default Supercharging ?
Hi, I figured of all the forums I frequent, this is THE place for a supercharging question. I am new to the concept of supercharging MY engine. I was formulating a build and then just when I was about to pull the trigger...BAM, someone came out with an elegant way (kit) to add a supercharger to an old pontiac engine and keep it under the hood...SOLD!!!!
Just an update- It will be a '68 468ci Pontiac block, aluminum heads, carburated. I am planing on a D1SC.
Now my questions.
1) Due to the price of the units themselves, I have been looking on ebay. Is a D1SC that came in a Mustang kit the same as if I bought one off the shelf? I know the brackets and some of the piping would be tossed but I would think I could reuse some parts.
2) Is there a simple diagram of supercharger plumbing? Like where does all that piping go into and out of?
3) If adding an intercooler, are they universal? The guy who builds the kits told me they are a $1800 add on, but I see them on ebay for $100-200.
4) Where does the intercooler fit in to the plumbing scheme?
Thanks, Jason
Old 11-26-2010, 09:50 AM
1. a D1sc is a D1sc. if you have any doubts you can allways call procharger with a serial #.
2. Piping is from blower to carb. The blow off type race valve goes in the pipe in between.
3. Do not buy a $100 intercooler off e-bay. They have to be sized for your application or they are a waste or a restriction. Procharger makes good intercoolers and so does Bell. (lots of others as well) Poor intercoolers even come apart under boost at times.
http://www.procharger.com/intercooled.shtml
4. blower - intercooler - carb and usually the valve between the carb and intercooler
you need a special blow through carb
http://www.procharger.com/bebs.shtml
There are drawings and lots of tech info on the procharger site
These guys do prochargers on pontiac engines, and I'm sure there are others. There are pics of installed kits on there site.
http://www.angelfire.com/fl4/pontiac...chineshop.html
I love boost!
Old 11-26-2010, 09:53 AM
camcojb camcojb is offline
Now my questions.
Thanks, Jason
1. as long as it's the normal rotation model it should be fine. They have some like the older Vettes where the blower faces the engine and it spins backwards, which would not work in the normal mounted systems. I recommend before you buy any used Procharger to get the serial number off of it and call Procharger to see if it's had any issues, blown up, warranted, etc. All the mounting brackets and piping would probably have to be re-done. If you have the ability to make them that's a way to go, but if you're planning on buying them from Procharger I'd recommend getting a price first, because it's almost always cheaper to buy the complete kit new than it is to buy a used blower and all new brackets, spacers, pulleys, etc. Procharger charges a lot to buy the stuff separately.
2. Should be some diagrams on the Procharger site.
3. Intercoolers are universal for the most part, although some are specifically sized and shaped to fit particular cars. You'll need to determine where you can fit one (if air to air it needs to be in front of the radiator). You have to watch sizing because if you get one that's too small or restrictive you can actually lose power by running it. Gotta watch the cheap Ebay ones, many are not efficient. Another to watch are the used Diesel units, again in many cases they can't flow well enough and in many cases the guys lost power. A lot of the Procharger guys don't run an intercooler and use water/alcohol injection instead. I've done that and it works great, plus with a blow through carb you get some additional air temp reduction. I prefer an intercooler but sometimes there's no room and/or no budget to get a proper one in.
4. An intercooler goes between the blower and the carb in your case.
Additionally, carb and carb hat make a huge difference in the power and driveability of the car. I had great luck with Scott at http://www.sd-concepts.com/pages/cfHome.cfm for my carbs. His were spot on out of the box, and worlds ahead of my own carbs modded as per Procharger.
Old 11-26-2010, 11:36 AM
Is a blow off valve needed? what does it do? where does it purge to?
Also, what are people paying for just the SC unit new? (not advertised, actual price)
Old 11-26-2010, 12:21 PM
You need the blow off valve to relieve the pressure built up when you back off the gas, otherwise bad things will happen.
Read all the tech info on the procharger site. If you just want a few pounds of boost you'll be ok, but if you want to make serious power you need to do lots of reading.
Old 11-26-2010, 01:27 PM
I'm looking to use 7-10 lbs max which should get me into the 700's.
Old 11-26-2010, 01:33 PM
it would actually use a surge valve with a Procharger, and yes it is needed. On a Procharged setup the valve would be open at idle and high vacuum times like cruising. Vents the extra pressurized air that stacks up in the intake when you don't need it there. Under boost it closes and allows full boost, and then coming off of boost, like if you snapped the throttle shut, it re-opens and vents the boost (usually to atmosphere) and prevents damage to the blower.
Old 11-27-2010, 01:43 PM
SuperB70's Avatar
SuperB70 SuperB70 is offline
How about twinscrew? They have zero lack and no need for intercoolers.
Old 11-27-2010, 03:06 PM
the twin screw superchargers like Kenne Bell use intercoolers. They're liquid to air and are built into the intake manifold.
Old 11-28-2010, 04:04 AM
SuperB70's Avatar
Yes newer high end models do have but you dont need it so bad as in others cos twinscrew don't make heat as much. In street/strip use you can drive without cooler. If you looking over 1000hp but then it wound fit under the hood.
Here, please go and read to chapter of intercooling: http://kennebell.net/KBWebsite/Commo...romcatalog.pdf
