Old 11-29-2010, 01:45 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default What brake line fittings do I need?
I'm planning on ordering a bunch of fittings to do my brake lines. Here's what I have so far. This is for the rear housing. What fittings would I need to do the front end leading to the back of the car. I have 4 wheel discs with a Wilwood master.
http://www.summitracing.com/search/?...=fbm5769&dds=1 One of these for the passenger side. Will connect to a hose that will run to the caliper.
http://www.summitracing.com/search/?...=fbm5030&dds=1 Four of these, one for each caliper.
http://www.summitracing.com/search/?...=fbm5556&dds=1 Two of these for the bulkheads.
http://www.summitracing.com/search/?...=fbm5815&dds=1 One of these for the driver's side. Will connect to a hose that will connect to the caliper. Another hose will run off the top to the hard line on the rail.
Any suggestions would be greatly appreciated. Thanks in advance.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
