Old 11-29-2010, 04:12 PM
tmadden's Avatar
tmadden tmadden is offline
Default Exposed metal prep advice
Okay guys. I had the car sand blasted a while back and due to the delay in metal repair it has developed surface rust. What is the best solution t remove it. I would rather do it myself and then seal it with something. Advice or suggestions???
Old 11-29-2010, 07:16 PM
elitecustombody's Avatar
D/A with 80 or blast it again. When done spray Picklex20 so you won't have to do it again
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 11-29-2010, 09:30 PM
tmadden's Avatar
With a wheeled grinder or just by hand? Thanks
Old 11-29-2010, 09:40 PM
FrankZ FrankZ is offline
I have to agree-----that Picklex20 is pretty amazing stuff.
Old 11-29-2010, 09:42 PM
GPR's Avatar
GPR GPR is offline
I use 80 da, wire wheel, course prep disc, hand sand and than apply SPI epoxy primer.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 11-30-2010, 05:58 AM
Wheeled grinder? I have no idea what that is. Use a D/A sander aka dual action sander.For tight areas you will have to do it by hand or use spot blaster.Make sure to remove any shiny glazed spots if you used wire wheel or prep disc
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 11-30-2010, 07:23 AM
tmadden's Avatar
Okay thanks. Now I understand.
Old 11-30-2010, 07:54 PM
T-Type T-Type is offline
i may be missing the obvious here but could you explain what the difference is between epoxy primer and this picklex 20 stuff? is the picklex 20 better to use if the metal is going to sit around longer w/out coating vs. epoxy primer?
Old 12-01-2010, 07:51 AM
picklex 20 is great when you want to leave bare metal without any primers for extended periods of time,if you're doing alot of metal work and it takes months to finish, you won't have to grind or remove primer to weld, picklex also makes welds cleaner.This is not a primer.
here is a link to their site, http://www.picklex20.com/
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 12-01-2010, 07:16 PM
MoparCar MoparCar is offline
Keep in mind that although Picklex 20 is excellent, it is not compatible with a few paint systems including House of Kolor. The primer will peel.
Just an FYI-otherwise it works great!
Wes
