Old 12-01-2010, 06:05 PM
Wybrow's Avatar
Wybrow Wybrow is offline
Default Cooling issues with a smaller AN style rad hose?
Ive seen multiple pictures of engines running AN style rad hoses, I would absolutely love to do this, but can only find -20 and -24 sized hoses/fittings. Would this create any cooling issues? I would think running a little higher gpm water pump would solve the issue of a smaller hose, just need some reassurance, thanks guys!
Old 12-01-2010, 08:49 PM
funcars funcars is offline
Take a look at the actual area you have for flow through your thermostat. It's less than the area of a -20 hose for most cars.
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
Old 12-02-2010, 04:17 AM
Wybrow's Avatar
Thanks for the input fellas
Old 12-02-2010, 07:46 AM
clill's Avatar
clill clill is offline
I just redid the engine in a NASCAR and I think I used a -16 hose and fittings ? The thermostat housing was machined for it. Here are a couple pics of the old setup. I used a different thermo housing than the one in the pic. 715 hp with no cooling issue.
Old 12-02-2010, 10:43 AM
kennyd's Avatar
kennyd kennyd is offline
i have a smallblock ,hilborn injected that has 2 upper hoses that are #8 an
and it runs cool .
Old 12-02-2010, 03:38 PM
Wybrow's Avatar
and it runs cool .
Wow, thats crazy, have any pictures? Id love to see that!
