Old 12-07-2010, 11:02 AM
yamadog yamadog is offline
Default Lets talk spindles!
OK guys- I'm starting to get my 67 Camaro back on the road after an eight year garage stint. Right now the car is stock front end with Hotchkiss coils and Herb Adams shocks. It does have factory disc. Of cousre I want great big brakes and an aftermarket subframe but I am the no budget for car parts guy. So I rememberd that the Stielow's Red Witch had c4 corvette spindles on it. Hmmm.....A quick trip to Ebay says I can buy theses spindles for about 100 per side. Then I can get much better brakes for almost nothing. I want to know how and why Stielow chose these spindles for that car. I assume that they are also taller than the Camaro spindles making the car handle better too. Are there any other advatages to c4 spindles? Why haven't a thousand other 1st gen Camaro owners done this swap? Anybody know what is involved in doing this swap? Thanks for any help and insight. Jason
Old 12-07-2010, 11:21 AM
Because it isn't remotely a bolt on affair. Everything needs to be changed to adapt them- from ball joints, to steering arm location. The amount of fab work required to make it work is not worth the money spent.
If you want an OEM quality forged aluminum spindle that does bolt on, Speedtech and the AFX spindle are the best option for the money.
Tyler
Old 12-07-2010, 01:33 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Tyler
I took Tyler's advice. My (former) 67 went from fun...to awesome. The guys at Speedtech will take very good care of you.
Have fun!
Curtis
Old 12-07-2010, 04:01 PM
DOOM's Avatar
DOOM DOOM is offline
Speed Tech! Talk to Blake he'll set you straight......
Mario
USCOLLISION
Old 12-07-2010, 04:36 PM
Bobs 67Camaro's Avatar
Bobs 67Camaro Bobs 67Camaro is offline
Make sure to get the Tall Spindles.
You can then bolt on C5 brakes. (you will need at least a 17" rim to fit C5 brakes)
Old 12-07-2010, 04:38 PM
Sorry, I meant to say--get the tall ATS spindles from speedtech.
If you have questions on C5 brakes, call Tobin at Kore3.
Old 12-08-2010, 04:34 AM
Spiffav8's Avatar
Lateral-g Moderator
X2 He's a great guy and the product is second to none.
Curtis
Old 12-09-2010, 10:01 AM
While I clearly understand that the AFX spindles do everything you could want out of a spindle, the 1100$ price tag is way out of my price range. That's why I was looking for info on how to use c4 spindles. I know they are not a 'bolt on' but I was hoping to discuss it with someone who has actually tried them. What REALLY needs to be done? Does it require a differrent ball joint or can you re-ream the holes in the c4 spindle? Isn't the Corvette a front steer car and the Camaro a rear steer? Were the spindles swaped side to side to put the steering arm in the correct relation? If the geometry of the steering arms are wrong, can it simply be cut off and re welded? Is there another factory spindle that will work? These are the kind of things I was hoping to discuss. Thanks again, Jason
Old 12-09-2010, 09:20 PM
Vince@Meanstreets's Avatar
What everyone will tell you that the work required to modify a C4 spindle would not only exceed the $1100 price, it would not benefit you at all as far as handling...to modify it further would make it an AFX spindle but with dated bearing pack and a limited brake choice range. Just because it fits will not make it right.
These guys are not giving you a hard time. This is not a new idea and has been discussed so many times on different boards too.
If you really want to try email Mr Steilow. He can give yo the run down but it will echo all that was said here.
Vince
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-10-2010, 05:44 AM
keep your eye open for unsued ATS spindles of your stuck for cash.... some guys change directions or run out of steam You have to be fast but you can get them at a great price if your patient... they are the right choice IMHO
