Old 12-09-2010, 11:20 AM
brownz brownz is offline
Default Line question for 2nd gen with LS1 p/s pump
I have a 1979 camaro with a AGR billet gear box with a f-body LS1 power steering pump.
Would like to know what an fittings and lines I will need to make the lines from the pump to the box
Old 12-09-2010, 03:29 PM
Blake Foster's Avatar
Hi Pressure is a 5/8-18 or 18mm inverted flare fitting
Russell # 640380
Low pressure is a 11/16-18 or 16mm inverted flare fitting
Russell # 648050
The factory fitting up to 1976 was a 5/8 and 11/16 Bump tube O ring fitting
this is the fittings that the LEE box comes with you may want to confirm with the MFG
the russell # are the fittings you ned to convert to -6 JIC male fittings
hope that helps
Blake Foster
www.speedtechperformance.com
