Old 12-11-2010, 05:45 PM
442 442 is offline
Default brake problems HELP PLEASE!!!
OK so i own a 72 olds 442 which i recentley did a brake overhaul on im running kore 3 kit Z06 brake calipers all the way around 6 piston 4 piston. I purchased a tuff stuff 9 inch dual diaphram booster and a wilwood tandam master cylinder 1" bore. I recentley installed everything including new brake lines I also gutted the factory combonation valve and use as a distribution block and installed a summit prop valve to rears. First problem i ran into is when bolting master to booster the booster rod pushes slighty against the master and compresses master piston slighty. Sencond i have excellent brake pressure to the fronts but absolutley zero brake pressure to the rears. ive bench bled master and pumped the brakes to bleed lines. seems like the fluid wont go down in the master for the rears no matter how much i try to pump n bleed. i need major help please
Thanks in advance
Old 12-11-2010, 11:19 PM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
You need to trim the "plug" that fits in the Wilwood master so that there is about .010 clearance. that is why you are not getting pressure to the rear as the piston is not returning all the way back in the master. This is where you should start.
Feel free to give me a call tomorrow on my cell (503-819-9043) if you need I am always glad to help
Luke Mau
L & H Kustoms
