Old 12-16-2010, 01:22 PM
bobbya312 bobbya312 is offline
Default NEW GM Type II P/steer pump $75.00,Brackets $35.00 ea Aluminum pulleys $35.00/set 3
New GM Saginaw type II P/steering pump with attached resevoir $75.00. It fits most late GM engines and the resevoir is removeable .Shown are 2 diff-erent style mounting brackets available for SBC $35.00 ea. If you buy the pump,and both brackets together, I'll include the aluminum P/steer pump, W/pump,and Crank pullys at no charge.If you want the pulleys by themselves $35.00.The top pulley is a 2 groove,bottom pulley is a 3 groove. This is a small block chevy, long waterpump setup. All prices shipped
