Old 12-18-2010, 08:03 AM
dinos67's's Avatar
dinos67's dinos67's is offline
Question LS3 intake options
I purchased a Ly6 6.0 motor and I am running the new 2010 Camaro LS3 intake of the motor I will be dropping in my 1967 camaro I wanted to use a drive by cable option does such a thing exist?
Old 12-18-2010, 08:51 AM
camcojb camcojb is offline
If you're asking if there's cable throttle bodies for that intake, yes there is. Fast, Accufab, and others make them that bolt up to the stock intakes. Which ECU are you going to run?
Old 12-18-2010, 09:41 AM
CarlC CarlC is offline
What Jody said. It's possible to run an E38 with a cable but it is a big PITA. The DBW is a much better option.
http:www.vaporworx.com
