Old 12-23-2010, 07:18 AM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default Stainless Works Headers w/BMR Sub Frame Connectors or Lowering Springs under $1375
YOUR CHOICE
This Package Contains
(1) Set Stainless Works
2010-2011 Camaro 6.2L 304 SS headers (New Design) with CNC mandrel bent 1-7/8" primaries and 3" slip fit collectors with high flow metal matrix catalytic converters and 3" lead pipes to fit factory connection point
and
(1) Set BMR Fabrications
Stiffen up the chassis for greatly improved handling with Sub Frame Connectors from BMR Fabrication. Constructed of 1" x 1" x .120 wall rectangular tubing and 3/16" CNC laser cut and formed steel plates, these Sub Frame Connectors use pre-existing bolt holes on the Camaro for a truly bolt-in piece.
The triangulating design stiffens and reinforces the chassis by joining three key areas of the vehicle's chassis: the front sub frames, carrier bearing location, and the rear sub frame where the rear suspension cradle mounts.
By fastening these three locations, the Sub Frame Connectors enrich the handling and response of your Camaro.
New hardware is provided for an easy installation time of only one hour.
or
(1) Set
BMR SUSPENSION Lowering Springs
Lowering the center of gravity not only provides visual appeal, it also dramatically improves the handling ability of your Camaro. BMR lowering springs are specifically designed to provide optimal handling without sacrificing ride quality. Our extensive development time produced what we feel to be the optimal rates for this application. By using a 220 lb/in front spring and a 460 lb/in rear spring the car responds with a firm yet comfortable ride with much improved handling characteristics.
All BMR springs are cold wound from high-tensile chrome silicon wire, stress relieved, compressed for permanent set then shot peened and computer tested. Some of these procedures are overkill but it ensures a long, trouble-free life with consistent rates and ride heights. Because of these features, BMR is able to offer a lifetime warranty against spring sag.
Lowers vehicle 1" front and 1" rear.
or
(1) Set
Lowers vehicle 1.4" front and 1.4" rear.
Package Price
$1328.95
includes shipping lower US
Call Toll Free 888.493.8041
PM
THIS OFFER ENDS DEC 30, 2010
YOU MUST CALL OR PM
OFFER NOT ON WEBSITE
Installation Available for Package
Call for Pricing
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
www.xplosiveperformance.com
