Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 12-24-2010, 09:16 AM
Gregster1234 Gregster1234 is offline
Default clutch kit 10.5 26 spline
I looking for a clutch kit that is a dual pressure for 600 hp and streetable.
Old 12-24-2010, 03:28 PM
Clutch are rated in torque. I have a few possibilities from mild to wild on the cost factor. Got any documented torque numbers? Or can you give us some engine specs? Cubes? Compression? Cam? Trans type? Gear Ratio? Car weight?
Frank Serafine
Old 12-30-2010, 06:46 PM
The dyno sheet shows 480 torque & 490 hp, I have a Quick Time Bellhousing RM-8020 which only accepts 10.5" clutch I will also need a small 153t flywheel hooking up to a Tremec TKO 600 using stock mechanical linkage. I was hoping to fing someone on hear wanting to unload a setup they weren't going to use or are going a different direction. I have already sunk money into a Lakewood Bellhousing and clutch kit and flywheel for a 11" setup and decided to go this route because I have to pull it apart to use a different clutch fork GM Camaro, I tried using the Lakewood fork and that's where it all went wrong!
Sorry for the long story!
Thanks,
Greg
