Old 12-25-2010, 11:31 AM
aronhk_md's Avatar
aronhk_md aronhk_md is offline
Default 98-02 Dual fans WS6/camaro & Lg 4 core radiator
I am pulling off my 4 core radiator and the twin fan this weekend. Its from a '98 camaro. Runs quietly.
The 4 core radiator is large but not original to my 73 trans am. I don't have the original radiator core support and I cant tell you exactly what it came from. It was chosen for duty because its large.
This setup kept my 73 turbocharged (almost 1100 hp) trans am cool in the heat of the summer. Only pulling it because I have a brand new aluminum radiator that I bought before this car and now a Lincoln MKVIII fan........since I'm putting A/C in the car I might as well use them.
Radiator is clean....took the best pic I could of the inside. Measurements are as follows:
Dual Fan
26.25" wide
18" high
6" deep
Radiator
33.5" wide including tanks Core itself is 27" wide
18.5" high
3" deep
Prefer to sell together as a package for $150......but will split if no quick buyer.
1973 Trans Am
73 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods
oh.......did I mention the 77mm Garrett turbo and methanol injection?
886 hp at the rear wheels, 1064 at the flywheel (calculated)@5500 rpm, before the methanol injection was added. Thank you Mark L...
