Old 12-25-2010, 11:37 AM
aronhk_md's Avatar
aronhk_md aronhk_md is offline
Default fiberglass cowl hood for 70-76 firebird/trans am
[SIZE="3"]This is an L88 cowl style hood for a 70-76 bird. It is a full bolt on style....bolts to your hood hinges. For use with latch, but has holes for pins as well. This hood was fitted, but never used or painted. Comes with the proper lightweight springs to use with your hinges. $350
I measured, and there is enough room in the cowl section to cut out for a shaker scoop if you desire. That was my plan, but instead I am doing a tilt glass front end.
SIZE]
1973 Trans Am
73 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods
oh.......did I mention the 77mm Garrett turbo and methanol injection?
886 hp at the rear wheels, 1064 at the flywheel (calculated)@5500 rpm, before the methanol injection was added. Thank you Mark L...
