Old 12-28-2010, 01:01 PM
Default Radio receiver only??
Hello ,
I am looking for a radio receiver unit only for my project. I am going to use Ipod for music source and dont need CD at all. Where could i get radio unit only? And in smaller size than standard DIN.
63 Z06
Old 12-28-2010, 01:55 PM
strtlegal's Avatar
strtlegal strtlegal is offline
I've learned from this site that some are not even using a head unit, just their Iphone or Ipod. Run that to an amp and to your speakers...
just another option
70 Nova: LS2/Tko600. Speedtech Stuff
Chuck D
Old 12-29-2010, 01:16 AM
just another option
Exactly what i am plan to use. But i do want the radio too.
I found this one : http://www.casmfg.com/Secretaudio.htm
63 Z06
Old 12-29-2010, 09:43 AM
FlameBroiled's Avatar
FlameBroiled FlameBroiled is offline
The SecretAudio will do what you want, it has a remote head unit that you can plug your Ipod / Memory stick into. Small display that can be mounted anywhere.
www.Eyekandykustoms.com
Old 01-08-2011, 08:44 AM
Vsolo's Avatar
Vsolo Vsolo is offline
This is what my son is getting (actually the 300 model)
http://www.crutchfield.com/p_158DSXS...0.html?tp=5684
There are 3 versions, if you want Bluetooth, you'll want the 300 model.
I like Crutchfield because they do the work & give you the extra stuff to get it done right the first time.
Here is a better picture of what it looks like inside
http://store.carconceptsonline.com/S...100_p_425.html
and the video
https://www.youtube.com/watch?v=IdpyfO5AEuE
HRPT 2011 Long Hauler
Old 05-02-2011, 07:38 PM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
just another option
Anyone have any Idea how they are accomplishing this, I don't want to run a head unit if I don't have to .
Old 07-16-2011, 04:54 PM
GTX's Avatar
GTX GTX is offline
http://www.installer.com/item/displa....php?it=spi336
With this cable,it connects to the Ipod headphone jack,then splits into 2 RCA inputs that connect to your amp input.You will have to plug the Ipod into your charger too for long trips though.The sound output from the Ipod is not that great,as far as voltage is concerned.Better head units put out 4 volts to get the signal to the amp,but if you're not an Audiophile,it will do.You will just have to crank the gain on your amp up.
http://www.crutchfield.com/s_113KDCX...FBrand|Kenwood
This is the route I took on my '70 GTO project...$140 and you get direct Ipod control,remote...so you could put it in the glove box,etc.,and it has 6 Hi-end 4 volt preamp outputs...and a 2 Year Warranty!!
http://www.amazon.com/Polk-Audio-Pa1.../dp/B0016LY6MA
This is the amp I got...It will run all the speakers,including subs with out the clutter of extra wiring.
