Old 01-04-2011, 08:52 AM
g356gear's Avatar
g356gear g356gear is offline
Default Ls7 - Th400 Trans
I have been talking with Jim @ Quicktime about running the TH400 on an LS motor and they do make the parts I need. Here are his comments.....
"The only bellhousing we have available for the TH400 transmission to Chevy is p/n RM-9045. In order to use it with the LS engine, you will need to space the torque convertor out approximately ¼” and use metric bolts to fasten the bell to the engine block. Also, you might have a slight clearance issue between the block plate and back side of the engine. "
Does anyone have any photos of these problem areas for a reference? Thanks.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
