Old 01-10-2011, 02:22 PM
BMR Tech's Avatar
BMR Tech BMR Tech is offline
Talking BMR Launches New Product - Weld-on Subframe Connectors for 1st Generation F-Body
BMR Suspension
Weld-on Sub Frame Connectors for the 1st Generation F-Body
Stiffen up the chassis for greatly improved handling in your 1st Gen F-body with Weld-on Sub Frame Connectors from BMR Suspension. This product is constructed from 2” x 2” x 0.120” laser-profiled square tubing and 3/16” CNC laser cut steel mounting plates. The BMR Sub Frame Connectors (SFC006) weld through the floor pan, connecting the front sub frame to the rear sub frame. The unique profile provides OE ground clearance and an unparalleled structural advantage compared to other designs. Provided with Delrin body mount bushings and grade 8 mounting hardware. Installation time is 3-4 hours.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
Brett
WWW.BMRSUSPENSION.COM
Old 01-10-2011, 05:02 PM
coolwelder62's Avatar
Those are very nice looking pcs.You guy's are building some really high quality part's.Keep us posted on the cool stuff coming from your shop. Scott
Old 01-12-2011, 09:38 AM
BMR Tech's Avatar
Thanks for the props!
Brett
Old 01-12-2011, 12:13 PM
Ron in SoCal's Avatar
These look nice and I do like the stuff you guys design, but I am curious - How does it offer unparalled structure rigidity over other through floor designs, and 3 -4 hours for a through floor install? Most similar products are in the 8 -10 hour range...
Ron in SoCal
69 Camaro in progress
