Old 01-11-2011, 12:29 PM
Blake Foster's Avatar
Default ATS Spindles With ZR1 hubs Now Available
I know in the past there have been discussions about wanting to use the ZR1 Race Hub on the AFX spindle and it has been a No Go. Well we now have it figured out.
We can infact retro fit the ZR1 hub to fit the AFX. this is by no means a cheap upgrade but it can be done.
The upgrade (cost if you currently have AFX spindles) hubs will be 999.00 sorry i dont make the hubs!! the total price including the spindles would be 1899.00.
Blake Foster
www.speedtechperformance.com
Old 01-12-2011, 09:55 AM
mfain mfain is offline
Ordered a set. Will post pictures when I receive and install them. Thanks Blake.
Pappy
Old 01-12-2011, 05:24 PM
TBART70 TBART70 is offline
What is the benefit to these stronger longer life?
-Tom
Old 01-12-2011, 06:54 PM
Default Benefits of ZR1 Hubs
Look at this thread (starting at pst #92) for a discussion
https://lateral-g.net/forums/show...=25680&page=10
Pappy
Old 01-13-2011, 09:07 AM
-Tom
thety were developed for the ZR1,mostly the problems they were having with the rear hub failing due to later loading, the flange is much thicker and the bearings are larger, also it looks like the flanfe has been hardened and is also coated. they all have the spline drive for the axle in them so they are rear hubs that GM uses on both ends.
i know Rupp uses them on Penny and Onelap will now be using them also, Mfain has a road race Corvette with AFX spindles and i have a set comming for him as well.
it is an expensive option but for the guy who really is going to race the cae and is looking for the best quality part avalilble this is it, you cant get any better.
Blake Foster
