Old 01-16-2011, 10:03 PM
ttchevelle's Avatar
ttchevelle ttchevelle is offline
Angry Two Walbro 255 Lph Pumps
Just got back from the dyno for my first pull. Fuel pressure fell to 33 psi @
4848rpm twin turbo set up made 447 rwhp with 15 psi boost. AFR went to
12.2. Realized that only one of my fuel pumps are working. I found the fuse blown
and the second pump is shorted. Is this comon for a walbro 255 pump?
1965 chevelle ls1 twin turbo/th400/currie 9 inch
Old 01-17-2011, 12:03 AM
camcojb camcojb is offline
In my experience the Walbro's are good pumps, no issues.
Old 01-17-2011, 05:00 PM
Hope you're running them on relays....
Ran a walbro for 6 or 7 years with zero issues. Putting a Walbro 255 in tank in the '32 Ford I'm doing EFI as we speak.
Old 01-17-2011, 05:56 PM
CarlC CarlC is offline
What's your fuel pressure at full boost?
http:www.vaporworx.com
Old 01-18-2011, 06:32 AM
ttchevelle's Avatar
33 psi. I found out that one of my pumps had failed after the fact. With only one pump we made 447 rwhp with the potential of alot more with two.
Old 01-18-2011, 07:25 PM
64duece 64duece is offline
We've had good luck with them aswell. Have you considered adding a fuel pressure saftey switch/transducer? We run multi-pump applications very often and always try to have something for safety just in case.....
Dennis
Moore Racecraft
Old 01-18-2011, 08:07 PM
ttchevelle's Avatar
Has anyone ever installed a wide band o2 and if so what type of gauge so I can constantly monitor my afr's? If my afr dropped it would be safe to assume I had a loss in fuel pressure.
Old 01-19-2011, 10:09 AM
I like the innovative setups - http://www.innovatemotorsports.com/
Just make sure to get the O2 sensor placement correct in the downpipe so the reading with be accurate.
Jeff Allen
J2 Speed and Custom
Old 01-19-2011, 06:12 PM
I like the NGK A/FX WBO2. Uses the better NGK vs Bosch sensor and stands up to heat and leaded fuels better. Should be installed atleast 12-14" after the turbo in the downpipe. Never install ahead of the turbo.
Dennis
Moore Racecraft
Old 01-19-2011, 07:36 PM
ttchevelle's Avatar
Thanks I think i'm gonna go with the innovate looks fairly simple.
