Old 01-20-2011, 05:20 PM
brans72 brans72 is offline
Default 98 LS1 wiring harness help needed please
I found a great link to the 98 LS! wiring harness connectors and was wanting more information on what needs to be removed besides vats,air pump,egr due to LS6 intake,traction control,Air injection reaction solenoid relay output-coil,Vehicle anti-theft system starter enable relay output--coil,Theft deterrent-fuel enable feed,and maybe a/c due to having vintage air set up for my chevelle. So did I miss anything or anything above need to stay? Really need help guys due to budget here. Also wondering what you have used to remove terminal pins don't wanna cut wires out if possible. Any help I can get would be very helpful and greatful!!!! Brandon
Also wondering where to find info for splicing in a OBD2 connector please. Thanks guys Brandon
Old 01-20-2011, 05:46 PM
dhutton dhutton is offline
i think you might need the AC request line to force your fans on when the compressor turns on.
Don
Old 01-20-2011, 06:58 PM
Ok did not think about that! Thats why I asked the question figured ask before I jumping in here. Thanks Brandon
Old 01-22-2011, 06:35 AM
ttchevelle's Avatar
ttchevelle ttchevelle is offline
As far as removing your pin terminals, you can buy a pin terminal from most of the tool trucks. Snap on, Mac and Matco Tools.
1965 chevelle ls1 twin turbo/th400/currie 9 inch
Old 01-22-2011, 07:29 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
also if you remove the terminals you need a way to seal the holes if you mount the PCM under the hood.
Old 01-22-2011, 12:33 PM
seen pin out tool before like red or green and use one before though it kinda sucked. Hoping to find a single tool not one with 4 ends on it. Anyone made something before to remove terminals? I plan on having pcm in the car but still a idea I will use. Anymore info guys on whats stays and what goes? Thanks Brandon
Old 01-22-2011, 12:37 PM
CamaroAJ's Avatar
to get the terminals out of the pcm all you need is a safety pin or a pick. you have to take off the red and blue terminal retainer and then you can see the tab to pull back and pull the terminal out.
Old 01-22-2011, 01:51 PM
yup got that part down now, Thanks. So now trying to figure out if my list is correct,incorrect etc on wires that need to be removed. Yeah I wish I could send it out but $$$$ is big problem if I ever wanna get this project even driveable or even finished so trying to learn. Brandon
Old 01-22-2011, 02:24 PM
Ok after doing some research today I need to do more! I found old post here talking about reworking 98 harness to pin out of a 99 - up and getting 99 up computer cause it is more friendly. So if any one wants to jump in and lend a hand I sure could use it!!!!!! Brandon
Old 01-22-2011, 11:30 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Call Jim at Jims Performance
http://www.jimsperformance.com/
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
