Old 01-29-2011, 09:30 PM
v8s10kid's Avatar
v8s10kid v8s10kid is offline
Default pump or regulator?
to cut it short ive got too much fuel pressure. im not sure weather to get an internally regulated fuel pump (mechanical) or a just add a fuel pressure regulator. the regulator is less then half the cost of the pump but i may have to run a return line.
its not a racecar, i dont even take it to open track days. but i am looking for some good ricer smokin power so i need 6 psi instead of the 7-9 im getting. which do you guys think is better?
pump im looking at is Edelbrock 1721
http://www.summitracing.com/parts/EDL-1721/
1984 v8 s10 - teal, short wheelbase, 15 inch rally wheels, 305 h.o. , muncie m22, dual super 40's, much more (daily driver)
1998 ford escort - enduro race car, 2.0 sohc, auto, only driven to church on sunday
Old 01-29-2011, 09:57 PM
camcojb camcojb is offline
several companies make similar pumps, they work well for the 550-600 hp range and under.
Old 01-30-2011, 08:09 AM
wmhjr wmhjr is offline
You don't need a return line with a non bypass regulator. I would pick up a deadhead regulator like http://www.summitracing.com/parts/AEI-13205/ . The 13205 gives you adjustability. If your pump isn't causing any issue other than the pressure being slightly high then this would fix you up.
