Old 01-31-2011, 10:43 AM
64skylarkls1 64skylarkls1 is offline
Default LS Conversion, headlights, AC
Hi Guys,
I'm doing an LS1 swap from an 02 Camaro into a 64 Skylark conv. I'm swaping just about everything. I mounted the 02 column and will be using most of the 02 harness.
Headlights - Perfect world would be do buy a round headlight conversion kit that the 02 harness would plug into with no wiring mods. Have not been able to find such a kit. Don't want to spend a ton on this detail. Any suggestions?
I'm also installing Class Auto AC but using the 02 compressor, condensor set up. I've looked at the wiring diagrams of both. To make the after market AC work with the 02 harness, it looks like all I need to do is take the new AC unit wire that's supposed to go to the compressor and tie it into the 02 harness where the 02 blower fan switch was - to the wire that goes to the body control module (I think that's what was called). I'm using the 02 radiator and fans as well. I'm thinking if I get the AC output to the correct harness input, I should be able to allow the engine rpm and cooling fans compensate as it did on the Camaro. Again, your thoughts are much appreciated.
