Old 02-07-2011, 01:54 PM
youthpastor's Avatar
Default LQ4 LQ9 6.0 Engine swap
I get lots of PM's of people wanting to know what is involved in a truck engine swap into a first gen. Camaro. Here are a few things needed and stuff I learned. Who knows- maybe a few others could chime in and we could make this a great reference. I will say right from the beginning that I thought doing a truck motor swap would save me a ton of $$ but by the time you swap everything over- it isn't that much savings- so here ya go:
Basics of a LQ motor swap
Fitment- The first thing you notice with a truck motor is the enormous intake and alternator mounting bracket that is way too tall for the first gen Camaro- I swapped the intake and throttle body for an LS6 intake- I understand an LS2 works also. When I bought mine is was $350ish for everything.
Oil Pan Autocraft-
Front AccessoriesI went with 99-02 Camaro accessory drive kit. I bought mine off Ebay- Pace Performance sells GM kits for a reasonable price. A/C will not clear the stock subframe -unless...it is a "peanut" compressor- I made my own brackets. Alot of guys on here show how to notch the stock frame to clear a regular size compressor.
Fuel This is the same with any LS motor swap. I use Rock Vally or Ricks - pump in the tank and a Corvette fuel filter with built in regulator- I think '98 vintage. Musclerodz has a reasonable priced tank with the pump already installed.
Computer A reprogrammed stock LS type computer - pre- 05 will work fine. I've used Wait4mePerfomance.com with great success. there are others also- Speartech, etc.
Harness There are also some great companies out there- I used PSI- it came with provision for dual electric fans, check eng light, etc. People get freaked out with the whole computer and harness aspect of the swap- but really- that is the easiest part. It takes longer to figure out where to mount the computer that it does to wire the engine. Ironworks has some slick brackets
Exhaust I've had great luck with Stainlessworks- I sure there are others out there.
Mounts seems like everyone has mounts now. I've used Speedway motor plates with Energy Suspension mounts for a Small block-
Performance upgrades A performance camshaft REALLY wakes these motors up- I use something with a 112-114 lobe separation around a .570 lift
OK so here's a start- anyone else want to offer some input
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
