Old 02-10-2011, 08:20 AM
snowskater6996's Avatar
snowskater6996 snowskater6996 is offline
Default Paint removal help!
Hoping someone can help me with a little problem. I have powder coated brake brackets that someone painted on top of. Is there something I can use that will remove the paint but not harm the powder coat? Thanks
"Nightmare"- 1972 Dodge Challenger
Daily Driver- 1994 Trans Am
Old 02-10-2011, 06:48 PM
kochevy67's Avatar
kochevy67 kochevy67 is offline
Did you try lacquer thinner yet. Try a small area first.
Old 02-22-2011, 06:37 PM
Jon Clough's Avatar
Jon Clough Jon Clough is offline
Most likely what ever you use to take off the paint will damage the powder coat below.
Old 03-13-2011, 08:07 PM
TheCntrion TheCntrion is offline
A citrus based paint remover may do the trick. Home depot sells it. I used it to remove some spray paint from clear powder coated aluminum and it didn't harm it.
