Old 02-10-2011, 08:41 PM
lutzy lutzy is offline
Default DSE Tubular uper arm caster bushings #1 or #2
About to install my dse upper and lower tubular arm set and came with two different sets of caster bushings. I could use either #1 or #2 bushings. Also you can flip the bushings for forward or rearward placement. Does anyone have any suggestion of which bushings to use? its going to be a street driven car...thanks
Old 02-11-2011, 08:06 AM
KPC67's Avatar
KPC67 KPC67 is offline
Hey,
If you call DSE they will be able to help you out.
Just thought i'd post so i wasn't leavin you hang.
Good luck.
Kevin Carter
