Old 02-14-2011, 12:38 PM
dinos67's's Avatar
dinos67's dinos67's is offline
Exclamation LS3 questions pulleys VVT 6.0
I have a stumper for you all I have a 1967 camaro that I am doing a LY6 swap into and the motor has VVT I pulled the truck intake and replaced it with the LS3 car intake and am also running the LS3 throttle body which is the drive by wire and I also swapped the truck water pump for the L99 2010 camaro water pump that is also VVT. I purchased a kit from Kwick Chevy Truck SUV LSx AC Bracket Kit (K10163) that relocates my ac compressor in the upright position and also purchased K10168 - Truck SUV LSx Alternator & PS pump bracket (K10168). Does anyone know if this kit will work with my L99 VVT car water pump the inlet is on the driver side?
