Old 02-21-2011, 06:33 AM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default 2010 Camaro Heavy Duty Front and Rear End Links by HOTCHKIS
by
Owners of 2010-2011 Camaros demand maximum performance from their cars. Seeing the need for stronger end links during hours of track testing, Hotchkis Sport Suspension has designed a high quality, adjustable end link set specifically designed for the Camaro. Front and rear links feature high quality 3-piece PTFE lined heim joints for smooth quiet operation, specially machined metric high articulation spacers, zinc coated grade-10.9 hardware and CNC machined aluminum sleeves with machined wrench flats. An excellent upgrade for your 2010 Camaro with Hotchkis sway bars. The adjustable design allows you to corner balance the suspension. A must have for any modern Camaro.
Features:
  • Highest Quality 3-piece PTFE Lined Heim Joints for smooth, quiet operation, not inferior 2-piece economy Heim joints..
  • CNC Machined Aluminum Sleeves with Wrench Flats.
  • CNC Machined, high articulation spacers designed specifically for the 2010 Camaro application.
  • High Quality Zinc coated grade 10.9 Hardware.
  • Direct bolt on application.
Benefits:
  • Reduces end link flex and fatigue
  • Increases sway bar effectiveness.
  • Allows for corner balancing suspension.
FRONT & REAR SET
https://www.xplosiveperformance.com/...ks_p_2254.html
FRONT SET only
https://www.xplosiveperformance.com/...t-_p_2255.html
REAR only
https://www.xplosiveperformance.com/...ar_p_2256.html
CALL TOLL FREE
888.493.8041
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
