Old 02-22-2011, 04:33 PM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default EDELBROCK PRO-FLO XT SEQUENTIAL FUEL INJECTION SYSTEMS 1986 & Earlier Small-Block
EDELBROCK PRO-FLO XT SEQUENTIAL FUEL INJECTION SYSTEMS 1986 & Earlier Small-Block Chevrolet Up To 450 HP (29 lb/hr injectors) Black
THE MOST COMPLETE FUEL INJECTION SYSTEM AVAILABLE
Edelbrock is known for complete performance packages that offer bolt-on performance ready to run right "out-of-the-box". Pro-Flo XT is no exception. Each package includes a complete intake manifold assembled with fuel injectors, fuel rails and throttle body, electronic engine control unit (ECU), handheld calibration module, Mallory® distributor, complete pre-terminated two-piece efi harness, fuel pump, fuel filter, fuel hose, attaching hardware and software. The unique two-piece harness offers quick connection of the engine and chassis harness at the bulkhead on the firewall for easy connection and quick removal if needed.
CHEVROLET 262-400 V8
DESIGNED SPECIFICALLY FOR S/B CHEVY'S These Pro-Flo XT EFI systems are ideal for converting carbureted engines to EFI. They offer more efficiency and driveability in Performer-level engines. This system is ideal for small-block Chevys in any type of vehicle from a 4x4 to a street rod or muscle car. Modern electronics complement the new Edelbrock Pro-Flo XT EFI manifold designed specifically for this EFI system. Kits #3528/#35283 are designed for 1986 and earlier small-block Chevy engines with Vortec-style heads like the Edelbrock E-Tec aluminum heads and offer even greater performance potential. For non-emission engines.
BrandEdelbrockManufacturer's Part Number35273
Part Type Fuel Injection Systems
Product LineEdelbrock Pro-Flo XT EFI Systems
Xplosive Performance Part NumberEDL-35273
EGR No
Injection StyleMulti-port
Metering StyleSpeed density (Map-N) and speed throttle (Alpha-N)Intake Manifold IncludedYes
Intake Section IncludedComplete
Intake MaterialAluminum
Intake FinishBlack
Engine Block StyleStock/OEM standard deckFuel Rails IncludedYes
Throttle Body IncludedYes
Venturi Quantity1
Venturi Diameter (mm)90.00mm
Throttle Body MaterialCast aluminumThrottle Body FinishNaturalInjectors IncludedYes
Calibration Module IncludedYes
ECM IncludedYesWiring Harness IncludedYesOxygen Sensor IncludedYesFuel Pump IncludedYes
Fuel Pressure Regulator IncludedYesDistributor IncludedYesMAP Sensor IncludedYes
IAT Sensor IncludedYes
TPS Sensor IncludedYes
IAC Motor IncludedYes
QuantitySold as a kit.
With a ready-to-run base calibration and the exclusive XT Calibration Module, the Edelbrock Pro-Flo XT EFI systems deliver proven performance and maximum tunability right out of the box. They come complete with everything required to install them on a small block Chevy with conventional or Vortec-style cylinder heads. The electronic control unit (ECU) is the heart of the Edelbrock Pro-Flo XT EFI systems. Its advanced features include fully sequential injection, downloadable calibrations for different engine parameters, and a host of options to customize the systems exactly to your specifications. These systems also support laptop tuning and closed-loop fuel targets with a narrowband sensor (included) or an optional wideband controller. Modern electronics complement the new Edelbrock Pro-Flo XT EFI intake manifold design. The eight equal-length runners and large plenum make this intake ideal for maximum power and drivability in the 1,500 to 6,500 rpm range. The Edelbrock Pro-Flo XT EFI systems come complete with an Edelbrock Pro-Flo XT EFI manifold, an Edelbrock 90mm throttle body, extruded aluminum fuel rails, and Pico fuel injectors that are assembled at the factory. They also include a programmable ECU, wiring harness, and exclusive calibration module. Available in a natural or brilliant black powdercoated finish, the Edelbrock Pro-Flo XT EFI systems bring a user-friendly design with high-tech components for the ideal high performance street vehicles.
CALL TOLL FREE
888.493.8041
PM
GET ADDED SAVINGS
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
www.xplosiveperformance.com
