Old 02-23-2011, 02:55 PM
g356gear's Avatar
g356gear g356gear is offline
Default 69 Camaro front/rear glass trim Install
For those that have done this before, is there a particular order to follow when installing the front and rear stainless glass trim pieces. Thanks!
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 02-23-2011, 03:34 PM
dhutton dhutton is offline
Can't say I know the order but I can recommend that you get some good quality clips. Steve's Camaro parts sells some for original style moldings or repro moldings. I used the original style after the cheap repop ones I had didn't work.
Don
