Old 02-24-2011, 05:21 AM
Macbuick's Avatar
Macbuick Macbuick is offline
Default Catalina brakes
Hello,
I own a 68 Pontiac Catalina Station Wagon with front drum brakes and i d like to install disc brakes. I contacted CPP but they told me that they don't offer a kit for the Catalina as it's not the same suspension as the Impala...
I thought that GM full size shared the same chassis and suspension?!
Do you know a brake kit for my car?
Thanks alot
David
[SIGPIC][/SIGPIC]
72 Skylark & 68 Pontiac Catalina+ 71 El Camino
Old 02-27-2011, 06:23 PM
73GA 73GA is offline
David,
Discs were an option on these back in 68 so you should be able to find either a service replacement kit or an upgrade kit from one of the major aftermarket companies. A little more searching and you are sure to be successful. There are actually a series of YouTube videos of a drum-to-disc swap on a 68 Catalina two door. I could only watch a little of a couple of them before I gave up, but if you can stick it out the guy doing the swap must mention where he got his kit. Good luck, be patient, and I'm sure you'll find what you're looking for. BTW, got any more pics of your 68 wagon?
Gavin.
Old 03-15-2011, 09:05 PM
64pontiac 64pontiac is offline
Do you have a picture of your suspension or your spindles? I am working ona 68 Parisienne for one of my employees, (Canadian version of a catalina)
and we are using wilwood components on a CPP drop spindle.
On our model it shares the same control arms as an Impala.....
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 03-15-2011, 10:43 PM
Radlark's Avatar
Radlark Radlark is offline
Here you can try these guys I had a 1969 Catalina and he was the only option for me hope this helps.
http://www.scarebird.com/index.php?id=1
Old 03-15-2011, 11:01 PM
wmhjr wmhjr is offline
Here's the deal, guys.....
You'll find that on the pontiacs, some things are the same and some are different. Usually the control arms and spindles are the same (usually - not always especially in the 60s) but other suspension items are often completely different, like center link, idler arms, pitman arms, etc. Believe me, I found out the hard way.
The guys to ask specifically about the '68 Catalina would be over on PY. There will almost certainly be some guys there who will know exactly what interchanges on one.
Old 03-16-2011, 01:06 PM
Macbuick's Avatar
Originally Posted by 73GA View Post
David,
Gavin.
[IMG][/IMG]
[IMG][/IMG]
I will make pictures of the spindles this week end....
[SIGPIC][/SIGPIC]
Old 03-19-2011, 11:17 PM
Wow, thanks David! I love wagons, (have a 77 Lemans Safari), and especially Poncho wagons. The stance of your Catalina kills and the wheels are perfect. Man, what an awesome push-car that would be for a nostalgia race car! Thanks again for the pics and let us know how the brakes work out. Cheers! Gavin.
Old 03-20-2011, 09:07 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
We have a 65 Pontiac Bonniville in the shop that we did custom Wilwood brake kits for.. I will post pics later this week..
Cris Gonzalez
