Old 03-06-2011, 04:06 PM
Rhino Rhino is offline
Default Best blasting media for aluminum?
I have quite a few aluminum pieces that I'm looking to clean up before install (engine block / pan, accessory brackets, control arms, etc..) and trying to find something that won't profile the metal too much. Today I tried some 80 grit black diamond, but even at low pressure I feel it's too harsh. Unfortunately it's the least aggressive media I've been able to find locally. Anyone else have any success blasting aluminum?
Old 03-06-2011, 06:09 PM
NOPANTS68 NOPANTS68 is offline
I've always had great results with glass bead. It leaves a frosted look to the aluminum parts.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 03-06-2011, 06:30 PM
That's good to hear. I found a place across town that has both glass bead and walnut shells. I plan on picking them up and doing some testing.
Old 03-06-2011, 06:51 PM
I tried the walnut first and found it didn't work well. The pieces bounce off of the material and don't have the tooth I was looking for. When I switched to glass, it was smooth sailing.
1956 Chevy 210
Newcastle , CA
Old 03-06-2011, 07:05 PM
clill's Avatar
clill clill is offline
I use the finest grit sand they sell and it looks shiney.
Old 03-06-2011, 07:09 PM
coolwelder62's Avatar
I use Glass beads.Really give's a nice finish w/o the use of paint.When you come to pick up your subframe bring a pc. and I give you a sample. Scott
Old 03-06-2011, 08:49 PM
What grit glass are you guys using? Turns out that the finest they have is 80 grit.
Which brings up another question... is it the grit or the hardness of the blasting medium that I should be most worried about? I can order in white aluminum oxide down to 220 grit.
Scott, Thanks for the offer. If I haven't found something that works before then I'll take you up on that. I have a lower A-arm that has a small section I tested today. It'd be interesting to see a comparison on the same material.
Old 03-07-2011, 06:40 AM
elitecustombody's Avatar
Rhino, check local Harbor Freight or Northern Tool, usually they have blasting media, although HF has ridiculous prices on media compared to the rest of their products,it might help you in a pinch.
I would try walnut shells or plastic, anything coarse will leave surface finish prone to get dirty quick and PITA to keep clean
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
