Old 03-07-2011, 04:06 AM
69Lt4's Avatar
69Lt4 69Lt4 is offline
Default Cutting 69 Camaro Dash Pad?
Curious on what people are using to cut their dash pad on a 69 camaro. Need to trim/cut it for the roll cage.
Thanks,
Kevin
69 Camaro LT4 T56 9" Baer, Budnik, DSE suspension Vintage Air........
Old 03-08-2011, 03:10 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Cut the vinyle first with a blade, Then you have a guide to cut the rest with airsaw. JMO
TRACY WEAVER
www.recoveryroominteriors.com
Old 03-11-2011, 05:05 AM
69Lt4's Avatar
Thanks.
A razor blade worked well in cutting. Used a die grinder with circular (barrel) sander to fine tune.
Kevin
