Old 03-16-2011, 09:17 PM
Sieg's Avatar
Sieg Sieg is offline
Default Heim joint clutch rods
Who manufactures the heim joint clutch rods for 1st gen camaro's?
Is there a worthwhile difference in pedal feel and feedback?
Thanks!
Old 03-16-2011, 09:38 PM
Jon Clough's Avatar
Jon Clough Jon Clough is offline
You might try Speedtech. I just got one for my 70.
Old 03-16-2011, 11:30 PM
Sieg's Avatar
Didn't see any on their website. I saw them somewhere and can't find the link, heim jointed adjustable. Though it was from one of Lat G's sponsors.
Edit - Found them:
http://cmc.speeddirect.com/itemdesc....%2D125&eq=&Tp=
I saw that Mary Pozzi made her own, I'm tempted, but for $90 these appear decent.
Old 03-17-2011, 10:30 AM
JKnight JKnight is offline
I made my own as well. Probably cost me about $50 in materials. There is an appreciable improvement in the slop of the linkage, and it does move a bit smoother. I think the adjustability is probably the greatest benefit though.
Old 03-17-2011, 11:39 AM
Sieg's Avatar
Thanks Jeff.
Did you use aluminum or steel tubing?
Couple hours of recreation to fab them?
Old 03-17-2011, 12:25 PM
I used Chromoly steel, overkill but whatever. Cut tubes to length, clean up the inside bore to get the threaded insert to fit. Welded the inserts and that's it. Very easy if you have the factory rods to work from as a template of sorts.
Old 03-17-2011, 01:14 PM
Sieg's Avatar
I was hoping to source some smaller bungs similar to these:
That would make the project pretty simple.
Thanks for the assistance.
Old 03-17-2011, 02:12 PM
Yep, exactly. I used the ones that look like A in your picture above. They're not too difficult to find.
Old 03-17-2011, 02:45 PM
I've been happy with my stock z bar setup.
Old 03-17-2011, 03:15 PM
Sieg's Avatar
I know.............
