Old 01-18-2006, 10:15 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
Default Push button shifter ?
What brand does Boyd us in that 59 impala and in the aluma tub ?
www.hotrodderjournal.com
Old 01-19-2006, 05:10 AM
Steve Chryssos's Avatar
Sold thru Mooneyes. Made by Retrotek.
Edit: Hard to find on their website so here's the link:
http://www.mooneyesusa.com/index.asp...OD&ProdID=1505
________________
Steve Chryssos
Ridetech.com
Old 01-19-2006, 11:09 AM
Musclerodz's Avatar
Wouldn't that freak them out. A hidden push button shifter combined with a paddle shifter.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-19-2006, 11:38 AM
TravisB TravisB is offline
Originally Posted by Musclerodz
Wouldn't that freak them out. A hidden push button shrifter combined with a paddle shifter.
Mike
my thoughts exactly
Kenny Davis Hot Rods
Old 01-19-2006, 05:30 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Steevo I believe we had that conversation about 6 months ago, LOL.
Jim
Old 01-20-2006, 11:44 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
I built a low budget version of this on our 23 T-bucket with a Turbo 400 trans.
I used a 4" linear actuator from www.uslinear.com mounted on the trans with a pivot on each end to actuate the shifter linkage.
I ran that through a power window switch. I ran the power for the switch through the brake pedal so the ONLY way the actuator can get power is if the brake is depressed. Therefore the only way it can go in and out of gear is if you are braking/stopped.
On the t-bucket you can feel when it goes in gear so there is no need for a indicator switch.
Old 01-20-2006, 06:15 PM
Most ingenious. Considering the Mooneyes deal is $999, you should go into production.
Jim and Muscelrodz--yeah. There's no reason why you can't use both as long as the units are installed on an electronic trans. The two products work independently.
________________
Steve Chryssos
Ridetech.com
Old 01-20-2006, 10:48 PM
Keith's Avatar
Keith Keith is offline
That was the original plan for the Chevelle but ended up with a Hammer instead..... it's pretty cool. Check it out... www.retrotekspeed.com
There's nothing more common than unsucessful men with talent
GENESIS CHEVELLE
Old 01-29-2006, 09:15 AM
Dodgenut64 Dodgenut64 is offline
i have a push button in my 64 dart......but its not the same thing of course
