Originally Posted by xabichin67
Blake,
On a 69 Camaro, can you run the high clearance uppers and lowers with afx tall spindles on a stock sub with the Chicane kit.
On the stock subframe you CAN use the Hiclearance Upper Control arm with the TALL Spindle and the Chicane Coilover conversion, Actually that is the EXACT set up the OneLap Camaro uses. so that should tell you how well it works.
The Hiclearance LOWER control arms are ONLY for the Speedtech Subframe.
