Old 03-21-2011, 04:12 PM
zapco23 zapco23 is offline
Default What headers to use?
I recently bought a '69 Camaro SS/RS with a '95 LT1 Vette motor(yes, I know it's a mid-90s swap but I have to live with it until I can get an LS) and tranny swapped in it. Question is:1)Do I get a shorty header for the '95 LT1 Vette motor OR do I get a header for a '69 Camaro SBC? 2) Looking to also buy a MagnaFlow #15896 exhaust 2.5" tubing. I'm new to this and never dealt with a swapped motor so I don't want any fitment issues. Thanks!
69 Camaro SS/RS X-11,DSE Speed Level 1 kit,DSE 3" rear leaf kit,DSE 600 steering gear,etc....
Old 03-21-2011, 05:27 PM
64pontiac 64pontiac is offline
I would probably get a set of long tube camaro headers for a sbc. Reason being, most exhaust kits will include enough material and bends to connect to the long tube collectors, and in the case of shorties you will have to build down pipes.
A set of headers like dynatech's sbc camaro headers will give you a ton of clearance, AND they have a matching exhaust kit that fits great and bolts right up to their headers with only a couple trim cuts!
There are many other great brands out there as well. I know edelbrock has a kit that includes headers and exhaust.
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 03-28-2011, 09:40 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
These are good and have great ground clearance
http://www.summitracing.com/parts/DOU-D368/
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 03-29-2011, 03:30 AM
130fe 130fe is offline
Post
Wow, an LT1 swap still in the car? How can you drive it? LOL Just kidding, like the others have said, you can use any small block chevy header designed for your chassis. One thing to find out is which frame mounts you have (the part that bolts to the frame and the motor mounts). There are a couple of different ones (width and height) and some headers won't fit well with one type of frame mount.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
