Old 03-22-2011, 09:36 AM
kjwalters kjwalters is offline
Default G-TEch Pro EGS Tachometer Wide Band O2
Hey guys
Hers is a sweet little setup for those of you who want a compact and discrete monitoring system all in one. This EGS setup comes with The OBDII option, Wide band 02, progressive shift light, and acclerometer upgrade. All said, thats a $1000 package.
Not only do you get a killer tach, but this system will allow you to monitor ALL the OBDII paramters, like Air temp, oil pressue, Fuel pressure, Spark advance, etc... etc.. and with the Wide band O2 it gives you a great tuning aid and has play back and as well. The accelerometer perfromace upgrade allows you to keep and track 0-60mph times, 0-100mph, braking distance, and everything other thing you expect from a good performace computer.
Hi RPM recall, and user setable warnings all at the touch of your finger tips. You also get a control module that you can mount on the side of the Tach or with an extension cable you can mount it anywhere.
This also has a user changale color selection that will allow you to match it to your preferance. This is a great product.
Take it all - $550 NEW, ONLY USED FOR MOCK UP !!!
