Old 03-23-2011, 09:57 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
Default Butt Weld Vs Step Weld
Not sure where I heard this but is it true that if a panel is stepped (say a quarter) that in the future it's possible that the repaired area can be seen or that area is too difficult to be worked?
Is it best that certain areas of the quarter be butt welded and some areas be stepped welded (for strength purposes)?
I plan to use Full Quarters but wanted to put my question to rest.
Thanks.
Ron
1969 Firebird, 4-speed Coupe
If GOD is for us, then who can be against us!
Old 03-24-2011, 04:14 PM
NsaneHotrodz's Avatar
NsaneHotrodz NsaneHotrodz is offline
Question
Which area are you concerned with?
www.nsanehotrodz.com
Dewayne Morgan
[email protected]
Old 03-24-2011, 05:39 PM
Ron Fox's Avatar
Are you asking which area of my quarter? Well, if it's true, any area this is step welded being seen in the future.
Are there ANY AREAS of the quarter that should not be butt welded but stepped?
Can the area at the very bottom of the quarter (where the patch panel would go) be butt welded?
Thanks.
Ron
Old 03-25-2011, 05:33 PM
Thumbs up
I butt weld almost everything. When you overlap panels it makes it very hard to work the area and it can hold moisture.
DeWayne
Dewayne Morgan
[email protected]
Old 05-03-2011, 01:02 PM
senor_Camaro senor_Camaro is offline
if your doing qtr panels I would suggest butt welding if your doing just skins its cleaner and you wont have to use as much bondo to smooth everything out. it just depends on how your installing them are you doing full qtrs or just skins replacement?
Old 05-03-2011, 02:05 PM
Ron Fox's Avatar
At first we thought about just cutting out the rot at the bottom of the quarters and around the wheel opening and welding in patch panels. My builder suggested a step weld since it would be stronger because of the angle at the bottom of the quarter.
Now I am going with full quarters (hopefully NOS quarters)
I like the Butt welds over the step welds.
Thoughts anyone??
Ron
Old 05-03-2011, 03:39 PM
All panels should be BUTT welded. And TIG butt welded not MIG.
And METAL WORKED --- the only filler used is after it's DP'd and then just for flattening to perfection. Anything else is just bodywork on a car after it's been in a wreck...
Old 05-03-2011, 03:40 PM
dhutton dhutton is offline
Patches should be butt welded in my opinion and if done properly are as strong as the surrounding metal.
NOS quarters seem more appropriate for a frame off resto of a special car such as a 69 T/A. Repop quarters are regularly used and there is no reason why a competent builder could not do a decent job of installing them.
Just my two cents, but you did ask for opinions...
Don
Old 05-03-2011, 04:28 PM
ironworks's Avatar
There is never a reason to step a panel to weld together. Butt weld it and do it right.
Old 05-03-2011, 06:53 PM
Talking
Sounds like you need a new builder
Dewayne Morgan
[email protected]
