Closed Thread
Old 04-05-2011, 08:09 AM
DiecastMusclecars's Avatar
DiecastMusclecars DiecastMusclecars is offline
Default 1970 Buick GSX Restomod (Pro Tour - Street - Strip - Show)
Buick Skylark (GSX Restomod Clone)
This is basically a Brand New car top to bottom and Totally Rust Free!
We've combined modern technology wrapped in a 1970 GSX theme.
Weighing only 3380 pounds and making nearly 600 HP this car is a blast to drive.
It's obviously not a real GSX but no expense was spared in an attempt to recreate the real deal with a small dose of Modern Technology to make this a modern day Supercar!
Only 2,600 miles have been recorded since its restoration so this car is like brand new yet.
Its never been driven in the rain and is stored in a climate controlled shop.
The ENTIRE car is showroom clean and would be at home on the street, strip or car show.
There will be website links posted to provide plenty of documentaion that this is a top notch restoration. (These are located at the bottom of this post)
Restored by
Car located in Wisconsin - $75,000.oo - Contact info below
This car was from California and totally rust free!
The interior is pretty much stock "GSX"
Wilwood Brakes were used which allow the use of the Factory 15" wheels as well as the 17" Billet Buick Rallye Wheels (Shown below)
LS2 motor was custom built and makes close to 600 HP & 500 TQ
Outstanding Features
Rust Free Skylark from California - All original Sheet Metal (Pics will show how solid this car is!)
1970 GSX features with Modern Technology (Modern Drivetrain, Brakes, Suspension, Steering etc...)
Lightweight - Only 3380 Pounds with close to 600 HP! (Car has never been raced but should easily run 11's)
July 2006 Lateral G.net Feature Car
January 2007 Car Craft Magazine Feature Car
March 2007 Car Craft.com Online Feature Car
2007 July Calendar Car (Sponsored by Budweiser)
2008 Resto-Mod Musclecars Book (Featured on Page 93)
Motor
402 c.i. LS-2 Custom Built & Dynoed by Wheel To Wheel Powertrain / Madison Hts Michigan
600 HP - 500 TQ
Callies Crank & Rods
Dart Heads / Ported
Hooker Headers
Chassis Dyno and Computer Super Tune - Hi Tech Motorsport
Computer / ECU - Big Stuff 3
Drivetrain
Tranny - 4L60E / 4 Speed w/ Overdrive Built by ATD
Converter - 9.5" 3600 Stall / Built by PTC
Driveshaft - Aluminum
Rear End - New 12 Bolt / Moser Engineering
Gears - 3:73 Ratio / Auburn Posi Unit
Pro Touring Wheels - 17" Billet Buick Rallye Wheels / Newstalgia Wheel.Com
Front Tires - BF Goodrich G-Force T/A KDWS 245/45R17
Rear Tires - Mickey Thompson Drag Radials 275/40R17
Stock Wheels - Factory 15" Buick Rallye Wheels (not included but will fit with the Wilwood brakes!)
Cooling System / Fuel System
Radiator - Aluminum - Built by Ron Davis Radiators
Fuel System - Stock Tank converted by Ricks Hot Rod Shop
Walbro 340 In Tank Pump
Aeromotive Fuel Pressure Regulator
Exhaust
Exhaust - Torque Tech 3" Aluminized Mandral Bent w/ X-Pipe
Hooker Headers
Mufflers - Flowmaster Super 40 Series
Front Brakes - Wilwood Light Weight Discs
Rear Brakes - Wilwood Light Weight Discs
SSBC Master Cylinder and Brake Booster
Stainless Steel Lines & Braided Hoses
These Brakes allow the use of the Factory 15" Wheels if prefered
Suspension
Rear Control Arms (Upper) Edelbrock / Adjustable
Rear Control Arms (Lower) Speedtech Performance / Billet Aluminum
Front A Arms (Top & Bottom) Global West
Front Shocks & Springs - QA-1 / Coil Over / Adjustable
Front & Rear Sway Bars - Global West
Rear Shocks - KYB
Rear Coil Springs - Global West
Interior
Seats - Factory Buckets
Shifter - Factory Floor Shift w/ 4 Speed Overdrive Conversion Kit
Steering Wheel - Padded 3 Spoke Sport Wheel - GSX Option
Factory Tilt Column
GSX Floor Mats - Legendary Auto Interiors
Dash - Stock w/ Factory Gauges, Speedo w/Speed Alert / Rallye Clock - All Std Equip for GSX
Dash Emblem - GSX by Buick - GSX only dash emblem
Aftermarket Gauges - Auto Meter / Temp & Oil
Tach - Hood Mounted - GSX Option
Heat & Air Conditioning - Vintage Air (Modern Technology and much lighter!)
Air, Tilt, Power Windows, Power 4 Wheel Disc Brakes, Quick Ratio Power Steering, Fuel Injection, Performance Suspension, Gas Milage!
Extras
Complete Spreadsheet of entire build costs (This was a 6 digit - top notch restoration)
All invoices, assembly manuals, dyno sheets & other tid bits associated with the build included
Copy of all books, magazines and calendar car was featured in
2 Sets of Wheels are available - 15" Factory wheels as well as 17" Billet Rallyes (15's are optional but not included)
Website Links Alot of great photos documenting this build:
My website - Documents the build up and just about everything else mentioned http://www.diecastmusclecars.com/ls1gsx.htm
Lateral G.net Feature https://lateral-g.net/members/miller/
Car Craft.com Feature http://www.carcraft.com/featuredvehi...gsx/index.html
Autokraft.org (This is the restoration shops website) http://www.autokraft.org/gallery/70gsx/
Car Craft Magazine Article Pages 1 & 2 http://www.diecastmusclecars.com/grex12.htm
Car Craft Magazine Article Pages 3 & 4 http://www.diecastmusclecars.com/grex13.htm
I can be reached at (715) 874-6037 from 8 am to 6 pm central time.
(715) 797-7625 after 6 pm
Todd Miller / DiecastMusclecars.Com
www.DiecastMusclecars.Com
Specializing in Diecast Musclecars
Eau Claire, WI
My Ride / 1970 Buick GSX - G-ReX
Old 04-15-2011, 10:34 AM
BanditDave BanditDave is offline
THis car is absolutely fantastic...I would love to own it. Best of luck with the sale!
Old 04-20-2011, 02:52 PM
Thanks for the compliment!
Eau Claire, WI
Old 06-01-2011, 10:09 AM
This car will be at the Mecum Auction in June.
Here is a link to the Details: Mecum Aution Website / GSX
Eau Claire, WI
Closed Thread
