Old 04-17-2011, 09:02 AM
davey davey is offline
Default 9" Ford Rear - $1200 (or make offer) - mostly complete
USED - but in good shape / assembled
9" ford rear (original housing) - cambered 0.5 degrees
28 spline axles with 5x5 wheel studs
3.55 heavy duty racing gears (35 spline pinion)
alum spool (28 spline)
NASCAR pinion support and bearings
35 spline yoke 3-5/8" x 1-1/8"
Strange Alum center section (carrier)
Rotors (machined with cleaning slots)
GM METRIC brakes (welded-on on brackets and calipers included)
Suspension mounts are setup for GM A-BODY (lowered):
Currie Upper Control Arm JonnyJoints
Currie lower control arm brackets
brackets for QA1 coil over welded on front of axle (to clear stock exhaust)
Spring perch and Shock brackets included (not welded on)
looking to get $1200 + shipping (or pickup) - or make offer
located in northeast PA (Wilkes-Barre/Scranton area)
