Old 04-17-2011, 01:53 PM
orangevert's Avatar
orangevert orangevert is offline
Default shifter wiring for a turbo 400? Help
put a new shifter on my turbo 400 and now I have no back up lights..
Looking for a diagram or info on this...
Thanks Kirk
Old 04-17-2011, 06:43 PM
bigtime's Avatar
bigtime bigtime is offline
What car? what shifter did it have? what shifter did you put in?
The origional switch was either in the console or at the bottom of the column. I guess you lost your neutral safety switch also.
Old 04-18-2011, 06:58 PM
orangevert's Avatar
Default 1967 Camaro
67 Camaro floor shifter, Went from a hurst ratchet to a BM Pro ratchet.. The old Hurst had neutral safety switch.. Same connections but I can't get lights to work..
Thanks Kirk
Old 04-18-2011, 07:03 PM
orangevert's Avatar
Default Wiring for a neutral safety switch and back up lights
[QUOTE=orangevert;343847]67 Camaro floor shifter, Went from a hurst ratchet to a BM Pro ratchet.. The old Hurst had neutral safety switch.. Same connections but I can't get lights to work..
Does any one have one these that they can take a picture of?
Thanks Kirk
