Old 04-24-2011, 06:18 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default QA1, FAST, Lokar and GM parts
Time to get rid of some stuff to make money for new parts.
QA1 coil overs, currently on a 68 Acadian (exact same as a Nova). All four have been installed on the car, but never used. The car is still in the build process. Fronts are part # HAL-DR4855P. Single adjustable. Retail at $159.95 each at Summit. The are a universal spring and are a true coil over. They are currently on a Speed Tech subframe. Springs: I have a set for a LS motor, part # 9-450. Retail at $40 each. I also have a set of sbc springs, but I think they are an inch too long.
Rears are part # HAL-DR5855P. Single adjustable. Retail at $159.95 each at Summit. They are also a universal spring and area true coil over. They are currently on a Prodigy Bar / Air Bar rear set up. Springs are part # 12-250. They retail at $40 each.
I'll take $600 shipped for the set. I would rather not separate, but if the set's not moving, I will consider it. SOLD
I've also decided to sell my FAST 102mm LSXR intake. It's been bolted on and never used. The only 'flaw' is that I wanted to see how easy it would be to sand it down smooth so there is a smooth part on top where I sanded it. I will also include the manifold seals which I bought separately.
EDIT: The intake is for a LS3/L92. It is part # 146102. I have all the bolts and hardware that came with it. As stated above, it also includes the manifold gaskets which do not come with the intake when you buy it. I bought these extra. They are about $25 for the set. I even still have the original box for it.
Here's a pic of in on the motor. You can see where I started to sand it. There's a bit of yellow on it from the sandpaper. If someone is interested in the intake, I will make sure that the yellow comes off. If the plan is to sand it down, then it won't really matter.
These are going for $950 at Summit and Jegs. I'll take $700 shipped. SOLD
Lokar universal throttle cable. New still in the package. $42.95 at Summit.
http://www.summitracing.com/parts/LOK-TC-1000HT/
I'll take $35 shipped. SOLD
GM replacement wiper motor. Part number 40140. Fits several cars including Camaro, Chevelle, Nova and many others. Also have a AC Delco washer pump. GM part # 4919332. Fits 64-68 Nova and 67-68 Camaro. Both new and still in the box.
Here's the motor: http://www.summitracing.com/parts/AA...n/?prefilter=1
Here's a picture that I found of the washer pump from Rock Auto. http://www.rockauto.com/dbphp/x,cata...o_4919332.html
Together they retail for $140. I'll take $120 shipped for both. SOLD
I start back to work it the morning so I don't get back to you right away, don't panic. I will get back to you hopefully that day or the next. PM me if interested.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
