Old 04-27-2011, 01:10 PM
suark's Avatar
suark suark is offline
Default Half height body bushings
I'm planning on installing a DSE subframe and using a t56 magnum in my 68 Camaro. What are the pros and cons of half height body bushings versus stock height?
Thanks for your opinions
1968 Camaro
Build thread: https://lateral-g.net/forums/showthread.php4?t=36348
Old 04-27-2011, 01:46 PM
wmhjr wmhjr is offline
I'll start off by saying my perspective is from an A-body and not an F-body. So, I'm guessing YMMV - significantly. I'll let the guys with the little toy cars speak about F-body cars.
That was a joke - just to be clear.
For my application, half height body bushings would have created some real problems. Using full height poly bushings, I've already run into clearance issues for my 1/2" stainless fuel lines, and for the upper shock mounts for my Varishocks. I was certainly able to work around them and it is not anyones fault- just a fact. But, if I had half height bushings I don't believe I could have even mounted my rear shocks without lifting the body, and I know my fuel lines would have needed to be rerouted. Also, it would have made the job of building a removable 4 point cage much more difficult.
I would think that a Unibody car might be a very different discussion altogether.
Old 04-27-2011, 03:13 PM
The biggest problem is the t56 mag to tunnel clearance. There are other inherit problems I could list later.
Old 05-04-2011, 12:09 PM
ModernMuseum ModernMuseum is offline
Concerning a first gen F-body, the tunnel is supposed to clear if you have the regular height bushing, right?
