Old 05-03-2011, 02:03 PM
Lenie's Avatar
Lenie Lenie is offline
Default Driveshaft angle/am I screwed
Engine at 4* angled down at yoke, rearend pinion is also at 4* facing down and sits higher then the transmission yoke. Driveshaft is installed and angles up from the tranny to the rearend at 3*. From what I've been reading, this isn't good is it ?
Lenie
Old 05-03-2011, 02:25 PM
The WidowMaker's Avatar
from what you have posted, youre front WA is 7* and your rear WA is 1*. obviously not what you want. you either need to shim the tranny up or lower the pinion more towards the ground. with those numbers i would start with both. you will be amazed at what even 1/4" under the tranny can do.
"The WidowMaker"
Old 05-03-2011, 11:40 PM
Lenie's Avatar
Thanks, I'll start working in that direction. I just thought if the rear pinion was higher than the transmission yoke that was bad ju ju. This I think I can fix by raising the trans as you've stated.
Thanks again
Lenie
Old 05-04-2011, 04:45 AM
68protouring454's Avatar
doesnt matter how there orientated, you just need minimum working angle for the u joints to work.
that comes down to what type of rear susp you have as they all vary in how much pinion angle change is seen under throttle
Jake's Rod Shop
Old 05-04-2011, 08:08 AM
Raise the trans as high as possible and go from there.....
Old 05-04-2011, 08:36 AM
Lenie's Avatar
will do, thanks
Lenie
Old 06-04-2011, 07:18 PM
andrewb70's Avatar
Sometimes it is not possible to raise the back of the transmission high enough to fix the working angles. I had this problem with my GTO and I decided to go a different route:
http://www.pro-touring.com/showthrea...ion-2.0/page28
Andrew
Old 06-04-2011, 10:15 PM
But, you don't even know it's fixed your problem.
Old 07-10-2011, 09:57 AM
andrewb70's Avatar
I actually do. It did.
Andrew
Old 07-11-2011, 03:52 PM
I did see that on Chevelles.com but you posted this before hand.
