Old 05-09-2011, 08:20 AM
latzoo latzoo is offline
Default LS1 Vintage air kit
Can I use the compressor from my LS1 engine in a Vintage air kit? As I am assuming since my Camaro is a non A/C car, I will require the complete VA A/C kit?
Old 05-09-2011, 09:20 AM
The ECm for the enigine has nothing to do with the A/C, the vintage Air is a stand alone system.. You could control the elcetric fans through the ECm if you want to instead of the triary switch, as long as you make sure the at least one fan is running anytime the A/C is on.
Feel free to call with any questions
Frank Serafine
Old 05-09-2011, 09:54 AM
dhutton dhutton is offline
Frank, I think you read computer where he wrote compressor.... Anyway, the GM compressor is not compatible with Vintage Air, it will fail sooner or later.
Don
