Old 01-24-2006, 07:42 AM
Derek69SS's Avatar
Default LT1 PCM - anyone locate it under passenger seat?
I'm about to order my LT1/4L60 harness from Speartech, and need to figure out the location where I'll mount my PCM, and how much wire I'll need to get it there. Under the passenger seat seems like a good place for it to me... any reasons why not?
I'm also considering under the dash on the passenger side, if I have room with the factory A/C.
Old 01-24-2006, 08:02 AM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Derek, Get the dimensions of the PCM and make sure it will fit under the seat first. The next thing is trying to hide that wiring under the carpet, kinda bulky so that might be something to consider.
Kurt
Old 01-24-2006, 09:03 AM
Derek69SS's Avatar
Well, I know it will fit under my current bench-seat, but I don't know if it will fit under the Procar Ralley Seats I plan to get in the future.
I was thinking for routing it under the carpet, I could split it into 4 small bundles to run side-by-side, instead of one big round bundle... maybe run it under the console if I can get past the shifter once I get the new seats.
Old 01-28-2006, 01:32 PM
rocketman's Avatar
under the dash sounds better,if something where to ever slip under the seat the pcm would be shot.i have seen guys bolt to the glove door.or the storage bin in the console.
Old 01-28-2006, 01:42 PM
907rs's Avatar
907rs 907rs is offline
Or, if space is limited under the dash, on a hinged panel under the package tray in the trunk...... ala Twister.
Bill
Old 01-28-2006, 09:27 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
There should be good room abouve the glove box...............I wouldn't do it under the seat, any type of moisture or anything will be bad.................
When we wire clients cars for ECMs we get them as high up and yet accessible if something ever has to be changed..............not to mention sometimes the added length in wire can wreck havoc with them..................Japanese car computers are bad for that...............
www.hotrodderjournal.com
Old 01-30-2006, 07:24 AM
Derek69SS's Avatar
I haven't looked ABOVE the glove box, but I know there's no space behind it. The factory AC makes the whole under-dash area look pretty crowded, but I want to get it out from under the hood to clean it up some. (looks bad enough with factory AC taking up the whole passenger side of the firewall )
